See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Map Help
ClusteredTable4
Ive created a map in graph builder, and dropped the population over color.  I am now looking create either points or markers that indicate specific locations on the map.  Is this possible? Can it be done with the Longitute/Latitude of the location? Can it be done with another code (zip, area, fips, etc).  Thank you for you help!
mzwald
Re: Map Help
You can do this with a column of latitude and longitude values.  JMP will recognize them and place them correctly over your map.  Just put latitude on y-axis and longitude on x-axis.  Make sure the columns are formatted as latitude and longitude before doing this.
