Making a custom design
In the custom design when i create and one of the factors is set to hard, there is no d efficiency. When evaluating the table the d efficiency changes. why?
statman
Re: Making a custom design
Without going too detailed, a 100% D-efficient design is typically only possible with an orthogonal, balanced, and unconstrained design space. When restrictions are introduced, a 100% efficient design is generally not possible because the constraints reduce the volume of the information matrix relative to the ideal (unconstrained) case, resulting in lower efficiency.
statman
