Rachael44
Make Into Data Table not working in Script
I'm running into issues trying to script making a Tabulate object into a new data table. I've tried both syntaxes below, but neither creates the table. I'm using this as one step in a larger workflow.
t2 = tbl << Tabulate(
	Add Table(
		Column Table( Grouping Columns( :Treatment ) ),
		Row Table(
			Analysis Columns(
				:"Attribute 1"n,
				:"Attribute 2"n,
				:"Attribute 3"n,
				:"Attribute 4"n,
				:"Attribute 5"n, :"Attribute 6"n,
				:"Attribute 7"n, :"Attribute 8"n,
				:"Attribute 9"n,
				:"Attribute 10"n, :"Attribute 11"n
			Statistics( Mean )
	Local Data Filter(
		Mode( Show( 0 ) ),
		Add Filter( columns( :A or B), Where( :A or B == "A" ) )
)) << Make Into Data Table();
and
	Add Table(
		Row Table(
			Analysis Columns(
				:"Attribute 1"n,
				:"Attribute 2"n,
				:"Attribute 3"n,
				:"Attribute 4"n,
				:"Attribute 9"n,
			Statistics( Mean )
	Local Data Filter(
		Mode( Show( 0 ) ),
Wait(1);
t2 << Make Into Data Table();
I'm on JMP 17.2.
hogi
Level XIII
Re: Make Into Data Table not working in Script
Hm, interesting.
In the first example, when you add some brackets it should work. Without the brackets you send the message to the table and not to the Tabulate object.
Names Default to Here(1);
(dt << Tabulate(
		Add Table(
			Column Table( Analysis Columns( :height ) ),
			Row Table( Grouping Columns( :sex ) )
The second option should work. Maybe there is a typo?
The easiest way:
use the gui, then go to the log and "steal the code" .
hogi
Level XIII
Hm, interesting.
(dt << Tabulate(
		Add Table(
The easiest way:
Rachael44
Adding the parentheses fixed it - all these issues were just from a typo. Thank you!
