David_Hanslian
Loop to set a normalization formula for several columns
Hi community,
I'm trying to write a JSL script to set a normalization formula with dynamic column reference.
What's wrong here?
"Mean(M4_pop)" & "Std Dev(M4_pop)" are fix columns that are to be used for the normalization.
dt = Current Data Table();
numCols = dt << Get Column Names( Numeric, "String" );
For( i = 1, i <= N Items( numCols ), i++,
     colName = numCols[i];
    normColName = colName || "_norm";
    dt << New Column(
        normColName,
        Numeric,
        Continuous,
        Formula( (colName- :"Mean(M4_pop)"n) / :"Std Dev(M4_pop)"n)
Re: Loop to set a normalization formula for several columns
Hi David,
there might be prettier solutions but this is one way to make it work:
    mean = "Mean(M4_pop)";
    std =  "Std Dev(M4_pop)";
    dt << New Column(
        normColName,
        Numeric,
        Continuous,
        Formula( (as column(colName)- as column (mean)) / as column(Std))
Cheers,
Jonas
You will have to evaluate colName to the formula
Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute
Hi David,
    dt << New Column(
        normColName,
        Numeric,
        Continuous,
Cheers,
Jonas
David_Hanslian
Hi Jonas,
thanks for your response. Small changes that led to sucess :)
