Neo
Neo
List not evaluating in Set Property - why?
The following works  for the data table "allData"
Data Table( "allData" ):sTest << Set Property(
	"Value Order",
	{Custom Order({"IP1", "IP2", "IP3", "IP4", "IP5", "IP6"}),
	Common Order( 0 )}
but the following does not- where am I going wrong?
myList = {"IP1", "IP2", "IP3", "IP4", "IP5", "IP6"};
	"Value Order",
	{Custom Order(myList),
	Common Order( 0 )}
When it's too good to be true, it's neither
Re: List not evaluating in Set Property - why?
Scripting Guide > Data Structures > Lists in JSL Scripts > Evaluate Lists . One option to getting that list evaluated is to use Eval(EvalExpr())
dt = New Table("Untitled",
	Add Rows(6),
	Compress File When Saved(1),
	New Column("Column 1",
		Character,
		"Nominal",
		Set Values({"IP2", "IP1", "IP3", "IP6", "IP4", "IP5"})
mylist = {"IP2", "IP1", "IP3", "IP4", "IP5", "IP6"};
Eval(Eval Expr(
	Column(dt, "Column 1") << Set Property(
		"Value Order",
		{Custom Order(Expr(mylist)),
		Common Order( 0 )}
	Add Rows(6),
		Character,
		"Nominal",
Eval(Eval Expr(
		"Value Order",
		Common Order( 0 )}
