RA899
Limits Change Using Manage Limits Platform. Old limits don't go away.
I have an issue where I'm trying to use the manage limits option to change limits on my current dataset. Following this example in here Example of Manage Limits . I'm able to change the limits and implement the new limits I need. However, the old limits don't go away. It shows up as a solid black line. I tried removing the spec limits from the column and re-implement it, but still no luck. It still shows up as a solid black line. I'm using graph builder on JMP 17.2.0. My dataset table is coming from .stdf file where I used the QuickLoad tools.
Any help would be appreciated. Thanks,
Re: Limits Change Using Manage Limits Platform. Old limits don't go away.
Are you using script to create the graph builder? Could it have reference lines set?
RA899
Currently I'm not using a script, but ultimately, I will use a script. Even without a script, by just going analyze > graph builder, the reference line at the old limit still shows up.
I don't remember having such issues in JMP17.2.0 so you might want to contact JMP Support
It was developed in JMP 17, and no issues have been encountered with Graph Builder and limit lines (it also supports setting them up easily).
Or even: Feel free to contact at [email protected] —  perhaps you can get a free 7-days evaluation key so you can check whether the issue is resolved in YieldOptiX.
