galactus3000
Life Distribution: Fixing p and fixing Weibull beta in DS Weibull and solving only for Weibull alpha
Is there an easy way to fix n of n + m Life Distribution parameters and solve only for the remaining m parameters.
Thanks.
galactus3000
David_Burnham
Re: Life Distribution: Fixing p and fixing Weibull beta in DS Weibull and solving only for Weibull a
Once you have fitted a distribution you have an outline called "Parametric Estimate - <Dist Name>".
The red triangle hotspot for this outline has an option Fix Parameter.  When you select this, below your profiler outline a second row of profilers appears (the outline name is Fix Parameter).  There are some fields and checkboxes that allow you to specify and lock parameter values then update the other parameter estimates.
-Dave
David_Burnham
-Dave
galactus3000
Bonus Question ... if I have three flavors of Life Distribution data, A, B and C, of common origin but different stress conditions, I might want to 'constrain' parameter p to be common all three, p=pA = pB = pC and likewise for b=bA=bB=bC, fitting the two (rather than six) parameters across the three datasets, while allowing for and fitting to unique values for parameters aA aB  and  aC
Thus fitting for 5 parameters rather than 9
David_Burnham
you're welcome ;)
-Dave
