Khi2 test & missing values - obtain % of total with missing values
Created:
Feb 4, 2021 04:39 AM
| Last Modified: Jun 8, 2023 5:28 PM(2251 views)
I made a Khi2 test and I would obtain in my table, the % of each effectifs compared to the total total (total tacking in account the number of missing values).
Probably you need to say which part of JMP you are using to allow folks to give more specific recommendations. But, if you are concerned with missing data generally, you should take a look at the menu option Tables > Missing Data Pattern (if you haven't already).
