hogi
Level XIII
Keyboard shortcut for "Help Scripting Index"?
In a script window, the user can right click on a function and click on "Help Scripting Index".
This opens the Scripting Index with the function selected.
Can this action also be triggered by a Keyboard Shortcut?
If not, can an add-in do the same:
- check where the cursor is in the code
- check for the surrounding function (with spaces etc.)
- open the scripting index on th e right page
Then I could assign a keyboard shortcut ..
9 REPLIES 9
Re: Keyboard shortcut for "Help Scripting Index"?
main menu("scripting index")
is the JSL that will open the Scripting Index
You should be able to add this to
     View=>Customize=>Menus and Toolbars
as a keyboard shortcut
I think to check cursor location you would need to use Windows API or something similar. If you can figure out where the cursor is you could most likely use something like:
Get Line Text (and other Script Box methods. Also see Scripting the Script Editor :(
New Window("Example", sb = Script Box("print(\!"Hello\!");"));
Print(sb << Get Line Text(1));
Open Help
Open Help(
	"Scripting Index",
	Search(Term("Open"), Match({"Contains Terms", "Match All Terms", "Ignore Case"})),
	IndexContext(Category("Functions"))
hogi
Level XIII
Thanks for the modules. Hm, unfortunately, more complicated than I hoped.
altenantive: wish to add a keyboard shortcut directly to jmp
https://community.jmp.com/t5/JMP-Wish-List/Keyboard-shortcut-to-open-Scripting-Index-on-the-correct-...
It is pretty simple. Select View > Customize > Menus and Toolbars. Find the Help > Scripting Index command in the list on the left side and select it. Assign the new keyboard equivalent you want near the bottom. I illustrate with Shift-Control-I (Windows example).
hogi
Level XIII
Hi @Mark_Bailey.
On my system, the command "Scripting Index" from "Help" just opens the Scripting Index.
Actually, exactly what it says ...
- but quite different from what The "Scripting Index" in the right context menu can do.
I apologize. I reread your original post and realized you were asking for something else. I was responding to some of the early replies instead of your request.
There are quite a few shortcuts JMP's script editor is missing. Such as move line up/down, copy line up/down, run line, run until cursor and so on (some of the useful can be found for example from Key Bindings for Visual Studio Code). Shortcuts should also be very easy to rebind.
I also have a long list of features/shortcuts I would like to have added, but haven't made wish list item for them (so I'll have to manage without for now).
hogi
Level XIII
run line:
enter on numerical keyboard
(if some text is selected, JMP just runs the selected text)
hogi
Level XIII
in JMP 17: Alt + double click
