Shoal
Jmp connect to AAS (Azure Analysis Service)?
Hi, I would like to know if it is possible to connect JMP with an AAS (Azure Analysis Service) ?
thanks
Ryan_Gilmore
Re: Jmp connect to AAS (Azure Analysis Service)?
Hi @Shoal,
What exactly are you wanting to do? I did see where Azure Analysis Services has a REST API that you could use to pull data into JMP using the JMP Scripting Language (JSL) (see Communicate with REST Web Service in the JMP Help).
Another option might be to use an ODBC driver for AAS.
Hope that helps.
Regards,
Ryan
