TIP_USER
Jmp Addins for Ver19
Good day!
Currently, I update my jmp to ver19, however my current addins is not compatible to newer version.
Please help me to convert ver18 Addins to latest ver19.
attached is my addins from ver18.
Thank you!
Re: Jmp Addins for Ver19
@TIP_USER The latest version of the JMP Student Menu add-in compatible with JMP 19 can be found over on the JMP Marketplace.
https://marketplace.jmp.com/appdetails/Student+Menu
I would check for new updates to the addins at the JMP Marketplace as suggested by @kristen-slappey and for the others, you need to contact the addin authors for their support.
