pniel
Jackknife Predicted Values
Dear developers.
I need to retrieve the predicted value from Jackknife
I saw an example of getting the value from the table in the scripting guide..
myJackVal = column(“Jackknife Distances”)<<Get Property(“Jackknife value”);
Unfortunately I don’t know how to save the values to the data table.
Can someone please help?
Thanks,
Pniel
Re: Jackknife Predicted Values
Hello Pniel,
I see that this post is from a while ago, so you might have figured out an answer to your question already. If not, this script might help with what you're trying to do.
dt = open( "$SAMPLE_DATA/Cytometry.jmp" );
mv = Multivariate( Y( :ForSc, :SideSc, :CD3, :CD8, :CD4, :MCB ) );
mv << Jackknife Distances( 1, Save Jackknife Distances );
jd = dt:Jackknife Distances << get values;
Regards,
Michael
Michael Crotty
Principal Statistical Writer
Manager, Statistical Documentation
JMP Development
Hello Pniel,
Regards,
Michael
Michael Crotty
JMP Development
UserLightNew
Thanks for the helpful answer, Michael. With regard to Jackknife distances, in the graph I can see an UCL value being displayed as well as a horizontal dashed line marking the UCL value. When I tried to extract the UCL value I realized it is stored in a FrameBox. Is there any way to extract the UCL value through JSL?
If you save the Jackknife distancies, the column that is saved has a Column Property called Jackknife Value.  You can retrieve that value with
     UCL = col << get property( "Jackknife Value" )
