PNash
JSL for using a column group in a formula
Hi;
New to JMP / JSL.  I'm trying to add a formula column at the end of a set of data that calculates the STD DEV of the column data.  The header data will be variable, so I need a generic assignment of column numbers.
My script is obviously wrong, otherwise I wouldn't be here but this is what I was trying;
dt << Group Columns ("Weeks", Column (2), 26);
dt << New Column ("STDEV", Characteristic, Formula (std dev("Weeks")));
Any guidance is appreciated!  Thanks!
-Phil
PNash
Re: JSL for using a column group in a formula
Nevemind, figured it out!
colgrp = dt << get column group("Weeks");
dt << New Column ("STDEV", Numeric, Formula (std dev(colgrp)));
PNash
