  • See how to interactively organize and restructure data for analysis. Register for May 29 webinar, 2pm US ET.
hasanurkhan
JSL coding debug - help needed with "Label"
In my JSL code, I am using
dtt<<Set Label Columns (:skew);
and I can see in the table that label icon is being added next to skew. Then I am using graph builder and within that routine, I have
Show labels(1),
But when plots are being generated, it is not showing Label. Can you please help on this? Do I need to add anything else?
Thanks much
17 REPLIES 17
hasanurkhan
Re: JSL coding debug - help needed with "Label"
Did you use the code as-is or you changed something?
dtt = Open("$DOWNLOADS/output_sorted_test.jmp");
dtt << Set Label Columns(:skew);
Summarize(dtt, byGroup0 = by(:layout));
Summarize(dtt, byGroup1 = by(:Label));
Summarize(dtt, byGroup2 = by(:Vt_flavor));
Summarize(dtt, byGroup3 = by(:Z_width));
nn = 1;
ii = 1;
jj = 1;
kk = 1;
dtt << select where(:Label == byGroup1[ii] & :Vt_flavor == byGroup2[jj] & :Z_width == byGroup3[kk] & :layout == byGroup0[nn]);
sel = dtt << get selected rows;
If(N Rows(sel) > 0,
	dt = dtt << subset(selected rows(1), selected columns(0));
	gb = dt << Graph Builder(
		Size(266, 228),
		Show Control Panel(0),
		Variables(X(:nmos), Y(:pmos), Overlay(:PDK)),
		Elements(Points(X, Y, legend(5), Label("Label by Row"))),
		Show labels(1),
			Dispatch({}, "nmos", ScaleBox, {Label Row({Show Major Grid(1), Show Minor Labels(1), Show Minor Grid(1)})}),
			Dispatch({}, "pmos", ScaleBox, {Label Row({Show Major Grid(1), Show Minor Labels(1), Show Minor Grid(1)})}),
			Dispatch({}, "Graph Builder", FrameBox,
				{Marker Size(6), Add Graphics Script(
					6,
					Description(""),
					Summarize(dt, byGroup = by(:PDK));
					colorList = {"Blue", "red", "Green", "Green"};
					Fill Pattern([0]);
					For(i = 1, i <= N Items(byGroup), i++,
						Pen Color(colorList[i]);
						theRows = dt << get rows where(
							:PDK == byGroup[i] & :skew != "tttt" & :skew != "ff" & :skew != "fs" & :skew != "sf" & :skew != "ss"
						If(Word(2, byGroup[i], "/") == "a",
							Line Style("Dashed"),
						theRows = theRows |/ theRows[1];
						xMatrix = :nmos[theRows];
						yMatrix = :pmos[theRows];
						Line(xMatrix, yMatrix);
				), Add Text Annotation(
					Text(byGroup1[ii] || "_" || "Z" || byGroup3[kk] || "_" || bygroup2[jj] || "_" || bygroup0[nn]),
					Background Color("White"),
					Filled(0),
					Font("Segoe UI", 14, "Plain")
Write();
hasanurkhan
This is very strange. I tried with one plot. Somehow it does not show the label. I also tried copying your code and ran - it does not show the label.  Below is what I get from a single plot and as you can see somehow the Label by row does not show up (as expected). I added in back, re-ran the script, it is same - no label.
Graph Builder(
	Size( 1430, 909 ),
	Show Control Panel( 0 ),
	Variables( X( :nmos ), Y( :pmos ), Overlay( :PDK ) ),
	Elements( Points( X, Y, Legend( 5 ) ) ),
		Dispatch( {}, "nmos", ScaleBox,
			{Label Row( {Show Major Grid( 1 ), Show Minor Grid( 1 ), Show Minor Labels( 1 )} )}
		Dispatch( {}, "pmos", ScaleBox,
		Dispatch( {}, "Graph Builder", FrameBox,
			{Marker Size( 6 ), Marker Drawing Mode( "Normal" ),
				5,
				Description( "" ),
				Summarize( dt, byGroup = by( :PDK ) );
				Fill Pattern( [0] );
				For( i = 1, i <= N Items( byGroup ), i++,
					Pen Color( colorList[i] );
						:skew != "ss"
					If( Word( 2, byGroup[i], "/" ) == "a",
						Line Style( "Dashed" )
					Line( xMatrix, yMatrix );
				Text( "cgate_per_um_Z120_dev1_s9999019999d9999019999" ),
				Fixed Size( 0 ),
				Text Box( {87, 62, 341, 134} ),
				Background Color( "White" ),
				Font( "Segoe UI", 14, "Plain" ),
				Filled( 0 )
Note: JSL copied into JSL object to assist in easier reading by TXNELSON
The script you pasted isn't the same as my script as I have
		Show labels(1),
which you do not
hasanurkhan
I tried that (snippet below). It still does not put Label in the graph. No clue what is wrong. Thanks
To be honest, neither do I have any idea what is wrong. If I run the script I provided you with (with slight window resizing) I get this with JMP18
And this with JMP19
hasanurkhan
Let me update the JMP version and see if that helps. Thanks much.
hasanurkhan
Also I am generating hundreds of plot, so activating by clicks will not work for my purpose. Thanks
