haleyhoewt
JSL Lock A Column based on Name
Trying to understand in JSL scripting if there's a way to actually lock columns based on their name in a table? Not sure if theres a simple way to do this or if i just need to create a subset based on the existing table (a few caveats with this solution). Very time consuming to search for each column name and then lock each column. Alternatively, if i can have any idea on how to modify column order, that's also another remedy to the situation.
Thanks,
Haley
Thierry_S
Re: JSL Lock A Column based on Name
Have you tried the following method?
:NAME << Lock( 1 );
Best,
TS
Thierry R. Sornasse
Thierry_S
:NAME << Lock( 1 );
Best,
TS
Thierry R. Sornasse
