Newbie2Jumpie
JSL: Extract day of week from datetime field (scripting)
Hi
I have a field START_TIME (datetime format), e.g.
15.06.2019 6:05
16.06.2019 8:12
17.06.2019 7:01 etc.
I would like to keep all days that are Saturdays and Sundays.
I imagine, by extracting I would receive a value like
START_TIME         SAT_SUN
15.06.2019 6:05             7
16.06.2019 8:12             1
17.06.2019 7:01             2
Then I just use keep 1s and 7s, right.
How would I do that with JSL script?
I tried approaches like
dt << New Column ("SAT_SUN",numeric,format(day of week(:START_TIME),"datetime")) ;
that don't seem to work.
Any idea?
Cheers!
Newbie
Re: JSL: Extract day of week from datetime field (scripting)
There is no need to create a new column to do what you want.  Here is a simple script that does what you asked for:
dt = Open( "$SAMPLE_DATA/Aircraft Incidents.jmp" );
dt << select where( Day Of Week( :Event Date ) == 1 | Day Of Week( :Event Date ) == 7 );
dtsub = dt << subset( selected rows( 1 ), selected columns( 0 ) );
Just qick idea (as I have to leave in a minute): If you want to keep all values you can just use the filter command and exclude all the others not matching SAT/SUN.
If you really want to remove the rows not equal to SAT/SUN then use SELECT WHERE and then delete rows.MAy someone can write a demo script :)
/****NeverStopLearning****/
ian_jmp
Level X
If needed, use 'Help > Scripting Index' to find more details of how the commands work;
NamesDefaultToHere(1);
// Make a table of random dates
n = 50;
startDate = Date DMY( 01, 1, 2016 );
endDate = Date DMY( 12, 10, 2016 );
dates = Sort Ascending( J( n, 1, Random Integer(startDate, endDate) ) );
dt = New Table( "Dates",
			New Column( "Random dates", Numeric, "Continuous", Format( "ddMonyyyy h:m", 35 ), Set Values( dates )),
// Add a formula for the day of the week
nc = dt << New Column( "Day of the week",
						Numeric,
						"Continuous",
						Format( "Best", 12 ),
						Formula( Day Of Week( :Random dates ) ),
						Value Labels(
							{1 = "Sunday", 2 = "Monday", 3 = "Tuesday", 4 = "Wednesday", 5 = "Thursday",
							6 = "Friday", 7 = "Saturday"}
						Use Value Labels( 1 ),
// Make a subset table
r = dt << getRowsWhere(:Day of the week == 7 | :Day of the week == 1);
dt2 = dt << Subset(rows(r), LinkToOriginalDataTable(1));
dt2 << setName("Weekend Dates");
