ileshem
JSL Compare value in row to the next row.
I am trying to use "FOR" and "IF" to create a condition column.
I have this table and I want the "Con" column to indicate if the age in the row after is lower then the current row. if yes "1" if not "0"
NameAgeCon
David230
Bari261
James120
Lora140
This is what I have: (doesn't work)
dt<< New Column( "Con", Formula( For( i = 1,i <= N Row( dt ), i++, If(:Age[i] >= :Age[i+1] , "0", "1", ))));
Your help will be appreciated.
Re: JSL Compare value in row to the next row.
Here is two ways to do this (Row() and Lag():
dt = New Table("Untitled",
	Add Rows(4),
	Compress File When Saved(1),
	New Column("Name", Character, "Nominal", Set Values({"David", "Bari", "James", "Lora"})),
	New Column("Age", Numeric, "Continuous", Format("Best", 12), Set Values([23, 26, 12, 14])),
	New Column("Con", Numeric, "Continuous", Format("Best", 12), Set Values([0, 1, 0, 0]))
dt << New Column("Younger than Next_Row", Character, "Nominal",
Formula(If(:Age > :Age[Row() + 1], "Yes", "No")));
dt << New Column("Younger than Next_Lag", Character, "Nominal",
	Formula(If(:Age > Lag(:Age, -1), "Yes", "No"))
ian_jmp
Level X
Is this what you are after?
New Table( "Ages",
	Add Rows( 4 ),
	New Column( "Age",
		Numeric,
		"Ordinal",
		Format( "Best", 12 ),
		Set Values( [23, 26, 12, 14] )
	New Column( "Younger than Previous",
		Numeric,
		"Nominal",
		Formula( If( :Age < Lag( :Age, 1 ), 1, 0 ) ),
		Value Labels( {0 = "No", 1 = "Yes"} ),
		Use Value Labels( 1 ),
		Set Display Width( 125 )
ileshem
Thanks, this could work but it will mark as "Yes" the row 3 (James) and i am trying to mark row 2 (Bari) with a "Yes"
Any other solution?
	Add Rows(4),
