  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
JSL Bivariate analysis with "by"-argument, group-by + fit as loop (?)
Dear Community,
Currently I am trying to automate several recurring JMP routines with JSL. My tables have after several hundred lines of code now the form I want to have and I fail in JSL on a supposedly simple bivariate analysis :(
As an example I have attached a simplified table. If you click through it is:
  • X = :days, Y = :Readout, By = :Classification
  • => SHIFT Hot button => Group by :Individuals => SHIFT Hot button => Fit each value
The resulting code copied from the editor is:
Bivariate(
	SendToByGroup( {Is Missing( :Classification )} ),
	Y( :Readout ),
	X( :Days ),
	SendToByGroup(
		{Is Missing( :Classification )},
		Fit Where(
			:Individuals == "Ind7",
			Fit Each Value( {Line Color( {212, 73, 88} )} )
		Fit Where(
			:Individuals == "Ind22",
			Fit Each Value( {Line Color( {66, 112, 221} )} )
	SendToByGroup(
		{:Classification == "A"},
		Fit Where(
			:Individuals == "Ind2",
		Fit Where(
			:Individuals == "Ind4",
			Fit Each Value( {Line Color( {61, 174, 70} )} )
		Fit Where(
			:Individuals == "Ind5",
		Fit Where(
			:Individuals == "Ind6",
			Fit Each Value( {Line Color( {204, 121, 41} )} )
		Fit Where(
			:Individuals == "Ind8",
			Fit Each Value( {Line Color( {40, 182, 143} )} )
		Fit Where(
			:Individuals == "Ind9",
			Fit Each Value( {Line Color( {162, 43, 221} )} )
		Fit Where(
			:Individuals == "Ind12",
			Fit Each Value( {Line Color( {196, 189, 43} )} )
		Fit Where(
			:Individuals == "Ind14",
			Fit Each Value( {Line Color( {39, 174, 174} )} )
		Fit Where(
			:Individuals == "Ind15",
			Fit Each Value( {Line Color( {197, 41, 201} )} )
		Fit Where(
			:Individuals == "Ind24",
			Fit Each Value( {Line Color( {142, 176, 40} )} )
		Fit Where(
			:Individuals == "Ind28",
			Fit Each Value( {Line Color( {40, 154, 190} )} )
	SendToByGroup(
		{:Classification == "B"},
		Fit Where(
			:Individuals == "Ind1",
		Fit Where(
			:Individuals == "Ind11",
		Fit Where(
			:Individuals == "Ind16",
		Fit Where(
			:Individuals == "Ind17",
		Fit Where(
			:Individuals == "Ind21",
		Fit Where(
			:Individuals == "Ind23",
		Fit Where(
			:Individuals == "Ind25",
		Fit Where(
			:Individuals == "Ind26",
		Fit Where(
			:Individuals == "Ind27",
	SendToByGroup(
		{:Classification == "C"},
		Fit Where(
			:Individuals == "Ind20",
	SendToByGroup(
		{:Classification == "D"},
		Fit Where(
			:Individuals == "Ind3",
		Fit Where(
			:Individuals == "Ind10",
		Fit Where(
			:Individuals == "Ind13",
		Fit Where(
			:Individuals == "Ind18",
		Fit Where(
			:Individuals == "Ind19",
	By( :Classification )
My problem now is that this script if I hard code it like this will not work with new Indiviudals, which will be added to this table. And I also realize that I have to work with lists and a For()-loop in some form.
For the lists, I started as follows:
//Writes only the different individual values of column :Classification into a variable
	classlist = dt:"Classification" << Get values;
	classvalues = Associative Array(classlist) << Get Keys;
//Writes only the different individual values of column :Individuals into a variable
	IDlist = dt:"Individuals" << Get values;
	IDvalues = Associative Array(IDlist) << Get Keys;
But how I now approach the For()-loop correctly, I unfortunately do not know...
Does anyone have any ideas or can help me?
vince_faller
Re: JSL Bivariate analysis with "by"-argument, group-by + fit as loop (?)
Here's a big class example that I think does what you want.
names default to here(1);
dt = open("$SAMPLE_DATA\Big Class.jmp");
dt << Bivariate(
	Y( :weight ),
	X( :height ),
	GroupBy(:sex),
	By( :age ),
	FitLine(1)
Vince Faller - Predictum
vince_faller
dt << Bivariate(
	Y( :weight ),
	X( :height ),
	GroupBy(:sex),
	By( :age ),
	FitLine(1)
I'm almost ashamed of my question.... I have no longer seen the forest for the trees.
