drblove
JSL - Adding a Table to a Journal
Another JSL question, I'm trying to put a table in Journal using JSL.  Here is what I am trying to do:
current_data_table << New Data View;
// Creating the Journal
nw = New Window("Journal Right Here", <<Journal,
	ob = Outline Box("Section 1",
        Text Box("Some description that we need here.", << Markup),
        Current Journal()[TableBox(current_data_table)]
Everything seems to be working but the TableBox code... I am sure it is something easy but it is stumping me.
Thank you in advance.
Re: JSL - Adding a Table to a Journal
Here is a very simple script that does what you want:
nw = New Window( "sample journal",
	<<journal,
	ob = Outline Box( "Selection 1",
		Text Box( "this is some description", Markup( 1 ) ),
		dt << New Data Box()
14 REPLIES 14
	<<journal,
drblove
Hi Jim,
Thank you for your response. It works great.  Quick question through, when I go to the Journal is shows the table with rows and columns  that are completely empty (like an Excel spreadhseet) versus just the rows and column with headers.  Any solutions?
Thank you in advance,
Brad
The reason it displays empty cells, is because it is a view into an existing data table.  Here is another script that just adds a visual copy.  The script has to be a little tricky in it's method to place the data table view under the outline box.
	<<journal,
		hlb = H List Box()
xx = New Window( "xxx", <<journal );
dt << journal;
hlb << append( xx );
xx << close window;
drblove
Awesome!  Thank you so much for taking the time to reply, completely works.
Brad
mann
Thanks for those last 4 lines.
ram
ram
Is it possible to append matrix to a display box without any for loop etc?
Append a matrix???
A mathematical matrix....... a = [1,2,3 4,5,6] ?
A matrix of text boxes?
ram
ram
Yes, A 2D matrix of numbers. I was thinking if it can be converted as a table, can it be directly append to a display box?
Thanks
This might work for you
names default to here(1);
myMatrix = [1 2 3, 4 5 6, 7 8 9];
nw=new window("test", vlb=vlistbox());
vlb<<append((as table(myMatrix))<< get as report);
close(current data table(), nosave);
(nw<<xpath("//NumberColBox"))<<set heading("");
