hans_deroos
JMPStart - Custome Window must be in front of Home Window
I would like my own Window menu to be the front window when JMP is started.
I tried to put my menu window script in jmpStart.jsl.  It loads the menu, but when loaded is at the back of the Home Window.  I tried to minimize the home window with a old suggestion of David Burnham.
ServerMenu = New Window( "Access to QAQC Add-ins", ......);
Main Menu("Minimize All");
ServerMenu << On Close(
  Main Menu("Restore All")
But still loads my menu window first and then the home window. (PS I don’t want to make the Window Modal)
Re: JMPStart - Custome Window must be in front of Home Window
Maybe you could try using Schedule with << bring window to front? This seemed to work for me but there might be better solutions around.
nw = new window("test");
nw << Set Window Size(1400,1400);
s = Schedule(
	0,
	nw << bring window to front;
	s << Close;
