kiz
kiz
JMP17 script data table subsets not automatically staying closed (not an issue in JMP14)
JMP17 is having issues with running my scripts that have been working perfectly fine on JMP14. With JMP17, it might look like the subset data tables per my script are not automatically staying closed and so when I hover over a data plot created using my script, the entire data points in the plot blinks consistently because all the subset data table keeps opening.
Does anyone know about any scripting discrepancies between JMP14 vs JMP17 with regards to Subset data table (or not) that can help shed some light on this issue?
Re: JMP17 script data table subsets not automatically staying closed (not an issue in JMP14)
When I think of a closed JMP data table, I think of it as having been removed from the JMP session.  Any interactive report based on the data from within the table, would have to be closed.  From your description of your issue, it does not seem that when you say "subset data tables per my script are not automatically staying closed", that the data table is actually closed, but rather not visible to the user by some other method.  Could you please provide more details on what the script is specifically doing when you describe a table as being closed?
