robust1972
JMP can not be closed properly after running SQL and doing analysis
 after running SQL and doing analysis, JMP can not be closed properly and data tables could not be closed without saving it. I am using JMP 12.2.0.
I could not share the script as it is connecting to the SQL server where I work. Any hints and helps will be appreciated!
Eric_Hill
Re: JMP can not be closed properly after running SQL and doing analysis
Hey, robust1972,
Given the privacy issues, please consider starting a Tech Support issue on this problem by sending e-mail to [email protected].
It will be difficult to diagnose without knowing the specific steps you are taking in the script (using Open Table vs. Query Builder, etc.).  If you could copy the script and remove the actual database connection information and anything else proprietary, perhaps you could post that (or send it to Tech Support if you go that route).
Thanks,
Eric
