Nickbuon1
JMP Value Label - segment
I am trying to use create value labels for a series of numbers by creating a similar format as in SAS format.
1-10 = 10%
11-19 = 20%
etc.
Value labels and scores not let me add a series of numbers to segment. but i may be wrong. The other thing would be to create another column and just use the formula to do the segmentation. I would rather not do the later.
Any advice?
Re: JMP Value Label - segment
The Value Label column property allows you to use ranges to set your values
Nickbuon1
Thanks!
did not know what the allow ranges was about.
Nick
