Rajat
JMP Tabulate by list of column names in JSL
I have table and I want to tabulate it by column "student", column "subject" and column "class" but column "Subject" and column "class" is not necessary to available in the data.
If it has column "subject" but not column "class" then it should tabulate by column "student" and column "subject".
If it has column "class" but not column "subject" then it should tabulate by column "student" and column "class".
If it has all the columns then it should tabulate by all three columns. Below are some examples.
Example 1: (It has both column "subject" and column "class")
Input:
ClassStudentMarksSubject
1A
10
Math
2A15Science
3A12Science
1B15Math
2B12Science
Output:
ClassStudentSubjectmax(Marks)
1AMath
10
2AScience15
3AScience12
1BMath15
2BScience12
Example 2: (It has column "Class" but not column "subject")
Input:
ClassStudentMarks
1A
10
2A15
3A12
1B15
2B12
Output:
ClassStudentmax(Marks)
1A
10
2A15
3A12
1B15
2B12
Example 3: (It has column "subject" but not column "class")
Input:
StudentMarksSubject
A
10
Math
A15Science
A12Science
B15Math
B12Science
Output:
AMath
10
AScience15
BMath15
BScience12
Please help me to resolve this problem.
Thanks
Re: JMP Tabulate by list of column names in JSL
Is this what you are looking for???
names default to here(1);
dt=current data table();
// The list of columns to look for
theList={"Class","Student","Subject", "xxxxxx","xxxxxx"};
allColList = dt << get column names(string);
// Remove any columns from theList that are not in the data table
For(i=n items(theList),i>=1, i--,
	If(n rows(loc(allColList,theList[i]))==0,
		remove from(theList,i,1)
// Run the tabulate
Tabulate(
	Show Control Panel( 0 ),
	Add Table(
		Column Table( Analysis Columns( :Marks ), Statistics( Max ) ),
		Row Table( Grouping Columns( eval(theList) ) )
If the different target columns play roles other than Grouping Columns, you will need to develop the code accounting for the different required input syntax.
6 REPLIES 6
Run each of the 3 scenarios on a sample data table, saving each of the scripts from each run, into a script window.  Then take each of the appropriate scripts and put them into the following script in the designated position
dt= current data table();
colNames = dt << get column names(string);
// Here is the IF() structure to add in the tabulate code to
If( N Rows(loc(colNames, "Subject" ) ) > 0 & N Rows(loc(colNames, "Class" ) ) > 0,
// Add in the tabulate code that has Student, Subject and Class
 N Rows(loc(colNames, "Subject" ) ) > 0,
 // Add in the tablulate code that has just Student and Subject
 // Add in the tablulate code that has just Student and Class
Rajat
@txnelson Thanks for replying.
Can we solve this problem with single block of tabulate script because in my original dataset I have many such columns.
Condensing the Tabulate code down to one set of code, would make the code far more complex.
When you say you have many more columns, can you explane further?
Rajat
@txnelson I have 5 column like Column "Class" and Column "Subject" which can be present in the data or not. Now to tabulate I have to give all permutation of IF conditions and each would have separate tabulate code. It will make code will become too messy.
Instead if we can do it with single Tabulate function in which we give all the list of columns and it will take only those columns which are available in the data.
Thanks
// Run the tabulate
Tabulate(
	Add Table(
Rajat
Thanks You @tsnelson
