kprentiss
JMP Script that changes the column USL and LSL properties
I have a JMP Script Function that obtains a set of spec limits from a text file that is stored within the "Ntwk Osnr Spec Table Filename" variable. I am trying to change the USL and LSL column properties of the "PctDiff_ModBer_q_calcBer column within the "Ntwk Osnr Data Table" data table. But when I run the following JMP script commands I do not get a scripting error but the USL and LSL column properties are not updated. The Spec Limit that is obtained from the spec limit is 1.7. When I step thru the following lines the value of 1.7 is updated within the Speclimit variable but the USL  and LSL Column Properties are not updated. If I set the Speclimit variable to a constant 1.7 then the USL and LSL Column Properties are set to 1.7 and -1.7 respectively. So the issue must be obtaining the value from the text file, but I can figure out the issue. Can some one let me know what the solution is to obtain the spec limit from a text file and have it update the column properties.
Include( "$CommonScriptPath/Function - Obtain Spec Limit Value.jsl" );
Speclimit = ObtainSpecLimit(
	Ntwk Osnr Spec Table Filename, DeviceType, "*", "*", "ber_diffQcalc"
dt = Open( Ntwk Osnr Data Table Filename, invisible );
Data Table( dt ):PctDiff_ModBer_q_calcBer << Set Property(
	"Spec Limits",
	{LSL( (Speclimit * (-1)) ), USL( Speclimit ), Target( 0 ), Show Limits( 1 )}
Re: JMP Script that changes the column USL and LSL properties
Make sure the values are numeric and try using Eval(EvalExpr()) and Expr()
Include("$CommonScriptPath/Function - Obtain Spec Limit Value.jsl");
Speclimit = ObtainSpecLimit(Ntwk Osnr Spec Table Filename, DeviceType, "*", "*", "ber_diffQcalc");
dt = Open(Ntwk Osnr Data Table Filename, invisible);
Eval(
	Eval Expr(
		Data Table(dt):PctDiff_ModBer_q_calcBer << Set Property(
			"Spec Limits",
			{LSL(Expr(Speclimit * (-1))), USL(Expr(Speclimit)), Target(0), Show Limits(1)}
Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute
The calculations you are specifying within a JMP List, will not be evaluated prior to execution.  Therefore, the statement must be fully parsed and evaluated before  The Substitution function will accomplish that
Eval(
	Substitute(
			Expr(
				Set Property(
					"Spec Limits",
					{LSL( __LSL__ ), USL( __USL__ ), Target( 0 ), Show Limits( 1 )}
		Expr( __LSL__ ), Speclimit * (-1),
		Expr( __USL__ ), Speclimit
