ytwu
JMP Script question: How to use variables to control "show group means"?
Hi all:
I have a question about Variability chart.
I am trying to use a variable "aaa" to control if the a certain variability chart need group means.
Below is the simplified code:
According to the log file, it seems that jmp does not substitute aaa to 0 so that it still plot group means even if
aaa=0.
Is there any way to let jmp to realize aaa is a variable?
Note: The values of aaa could be 0, 1 or "Split1"
Thanks
Code:
aaa = 0;
Variability Chart(
	Y(:Name("DIMPLE LG (NM)")),
	X(:LOT, :DIMPLE LG),
	Show Group Means(aaa)
Re: JMP Script question: How to use variables to control "show group means"?
Eval(EvalExpr()) usually works in situations like this
dt = Open("$SAMPLE_DATA/Variability Data/2 Factors Crossed.jmp");
show_means = 0;
Eval(EvalExpr(
	varchart = dt << Variability Chart(
		Y(:Measurement),
		X(:Operator, :part#),
		Show Group Means(Expr(show_means))
