Sebastienlg
JMP Script : PDF report / line return instead of page break
Hi everyone,
I am creating a PDF file based on the dataset imported in JMP.
My dataset is around 100 columns and 3 rows.
The generated PDF report is not amazing. Indeed, each page of the PDF contains 7 or 8 columns and only 3 lines. Is it possible to have a line return and not a page break when the table is at the end of the page?
Thank you
Sebastien
Re: JMP Script : PDF report / line return instead of page break
I'm not aware of any way to do that, but what if you transpose the table first? That would increase the information on each page of the PDF.
