Sebastienlg
JMP SCRIPT: dashboard displayed horizontaly
Hi all,
I was able to create a dashboard with a column switcher, a table and a graph.
However, the table and the graph are displayed below the column switcher.
Do you know if it is possible to create a dashboard with the table and the graph which are displayed on the right of the column switcher (horizontally and not vertically) ?
It would be easier to see everything quickly...
In the script help, they are organized that way without any line of code to mention this.
Thank's a lot for your answer,
Sebastien
0 REPLIES 0
