Polyabc
JMP HTML - graph builder
I have a script in which i save as interactive HTML file. All the "regular" graphs look fine, but the charts built in graph builder  dimentions are not right, and look too high for the length. Anyone know how to fix this?
I'm using JMP15.
Thanks!
Re: JMP HTML - graph builder
Hi @Polyabc ,
If you could, please share an image of what you're seeing. If I understand it better, I may be able to help. Please block out any sensitive information.  Or, if you see the issue with one of our sample data sets, please use it to share an image of the issue.
Thanks,
~John
