jabenir1
JMP DOE help on prediction profiler
Hi all,
I am new to JMP DOE. I have a problem.
I have made my own set of runs without using JMP DOE tools. But I need to get the prediction profiler from that set. How to?
Please help, I cannot redo my experiments.
Thanks.
ian_jmp
Level X
Re: JMP DOE help on prediction profiler
Don't worry - So long as you have the results you can make some progress (though how much will depend on the design of your runs). In this case, the workflow in JMP requires that you fit some kind of model to your data (if you had generated a design via JMP you would have a saved script in the table to get you started with this step). Once you have a useful fit, the Prediction Profiler will be available in the report window. You can also elect to save the prediction formula(s) from the fit to the data table, then use the Prediction Profiler outside of the fitting platform.
Probably you need to fit some kind of linear model, so I would look at this aspect of Fit Model to start with.
ian_jmp
Level X
Documentation on fitting models is readily available from the pull down menus
     Help==>Books==>Fitting Linear Models
The excert below, from the book's Table of Contents, you can see there are lots of examples on how to setup the type of Fit Model you may need to use
Model Specification Specify Linear Models                       31
	Overview of the Fit Model Platform                      32
	Example of a Regression Analysis Using Fit Model        33
	Launch the Fit Model Platform                           36
	Fit Model Launch Window Elements                        37
	Construct Model Effects                                 39
	Fitting Personalities                                   45
	Model Specification Options                             47
	Informative Missing                                     49
	Validity Checks                                         50
	Examples of Model Specifications and Their Model Fits   50
	Simple Linear Regression                                50
	Polynomial in X to Degree k                             51
	Polynomial in X and Z to Degree k                       52
	Multiple Linear Regression                              52
	One-Way Analysis of Variance                            53
Two-Way Analysis of Variance                                54
Two-Way Analysis of Variance with Interaction               55
Three-Way Full Factorial                                    57
Analysis of Covariance, Equal Slopes                        59
Analysis of Covariance, Unequal Slopes                      60
Two-Factor Nested Random Effects Model                      62
Three-Factor Fully Nested Random Effects Model              64
Simple Split Plot or Repeated Measures Model                65
Two-Factor Response Surface Model                           66
Knotted Spline Effect                                       68
jabenir1
Thank you very much for this. I don't know much about JMP yet really and this gave me additional knowledge.
I tried running my design in 'Fit Model' and then run the profiler and got what I need. Again, thanks.
Peter_Bartell
Level VIII
To add to my colleague @ian_jmp and @txnelson's comments, going forward using JMP for empirical modeling purposes, the JMP Prediction Profiler permeates many, many modeling platform methods within JMP. For example, a Prediction Profiler can be found in the tree based modeling methods in the Predictive Modeling platform or the modeling based subplatforms in the Consumer Research section as well.
