VladimirB
JMP Alert Could not find succicient number of points
I wonder if somebody has encountered similar issue and have a way around it.
You responses / comments /suggestions / critique are very much appreciated!
I am using regular JMP 17 (not PRO).
I am trying to create a space filling design with 14 factors.  Some are continuous, some are discrete numeric, some are categorical.  There are 5 disallowed combinations.
When I put everything in, only "Fast Flexible Filling" design is available.  When I try to use it, it replies:
"JMP Alert  Could not find sufficient number of point"
This happens regardless of the number of points I specify.
To make sure that I don't over constrain the problem, I generated the "Custom" design with all the same factors and disallowed combinations.  And even the same number of points.  - No problem here!  (Of course I had to specify the model, for which I used Quadratic RSM).   I was able to generate I,A,D, and Alias - optimal designs.
My 2 questions are:
1) Why Space filling design is not working in the situation where Custom designs are working well
2) Is there any way around this problem for space filling design?
Thank you very much for you responses / comments /suggestions / critique!
Re: JMP Alert Could not find succicient number of points
Hello @VladimirB ,
I think that you should contact JMP Technical Support (support@jmp.com) about this problem.
VladimirB
Good idea!  Will do.
Thank you!
              Vladimir
