JMP 18 Update
How is the JMP 18 maintaince updated pushed out?
Does this require any user interaction?
It seem that after an update, it asked user to re-authenticate again.
Thanks
Re: JMP 18 Update
Go to
     File=>Preferences=>JMP Updates
If you check the check box, it will tell you when you start a JMP session is an update is available
There is also a Button that you can click on to check in real time if one is available
Re: JMP 18 Update
Updating JMP will typically require reauthentication.
Brian Corcoran
JMP Development
