ralphtedesco
JMP 18 Set Script difference to JMP 17
Hello, I have recently updated to JMP 18 and I am noticing a difference to the set script function when used in an application script.
On JMP 17 I could right click the created box and click Set Script to modify the script directly.
On JMP 18 though when I try and do the same thing the script is not in the script editor and I have to revert back to the application.
Is this a preference that did not get updated or was some functionality changed with the version changes that now requires additional scripting?
Thanks.
Re: JMP 18 Set Script difference to JMP 17
Hi @ralphtedesco
I'm not sure of the exact functionality changes here, but I would suggest raising this with [email protected], they will be best equipped to help.
Thanks,
Ben
