WoHNY
JMP 18: Analyze > Multivariate Platform Is Spearman's Rho Scriptable?
Analyze > Multivariate Methods > Multivariate, simple script below generates correlation table. Then I click on the red triangle, to the left of Multivariate, and select Nonparametric Correlations > Spearman's p. Is generating this Spearman's table scriptable?
// Launch platform: Multivariate
dt = Data Table("CorrData") << Multivariate(
	Y(:Response, :P1, :P2, :P3),
	Variance Estimation("Row-wise"),
	Matrix Format("Square"),
	Scatterplot Matrix(0),
	By(:Parm Name)
Re: JMP 18: Analyze > Multivariate Platform Is Spearman's Rho Scriptable?
After you do that, just go to the red triangle and select
     Save Script=>Script Window
and it will show you the script
Multivariate(
	Y( :age, :height ),
	Variance Estimation( "Row-wise" ),
	Scatterplot Matrix( 1 ),
	Spearman's ρ( 1 )
Multivariate(
	Y( :age, :height ),
	Spearman's ρ( 1 )
WoHNY
Jim: Thank you for that.
