BHarris
Is there a way to see just my Wish List posts?
I’ve added a few items to the Wish List board and was trying to find a way to pull up just the ones I’ve submitted. I couldn’t find a filter or search that seems to do that.
Is there an easy way to view only my own Wish List posts?
Appreciate any pointers — this one’s been surprisingly hard to track down.
BHarris
Re: Is there a way to see just my Wish List posts?
JMP Support has confirmed that this is not currently possible.
I've added a Wish list item here:  Add "My Wish List Submissions" view to JMP Community forum - JMP User Community
If this still works: https://community.jmp.com/t5/JMP-Wish-List/idb-p/jmp-wish-list/tab/my-ideas
if it doesn't you are stuck with the search and you can try to limit it by author (and wish list)
BHarris
That page shows my ideas, but also shows other people's ideas that I have commented on.
I tried to use the search feature and limit it by author, but it always just shows "0 results".  Does it work for you?
Search only works sometimes, no idea why but I think it would give you similar results as that page will. You could maybe use the API and query the results that way into a JSON if you are willing to write some code.
BHarris
