lehaofeng
Level V
Is there a way to save a jmp-formatted table that doesn't contain .jmp in the filename?
Why is it that when you use the command save() to save a jmp-formatted table, the saved filename has to contain .jmp. Is there a way to save a jmp-formatted table that doesn't contain .jmp in the filename?
Re: Is there a way to save a jmp-formatted table that doesn't contain .jmp in the filename?
I have not done that, however, you can always rename the file after it has been saved
dt << Save( "$temp\Big Class.jmp" );
rc1 = Rename File( "$TEMP/Big Class.jmp", "namewithoutanextension" );
show(files in directory("$TEMP"));
Close( dt, "NoSave" );
lehaofeng
Level V
That is a good workaround!
