Herrera5238
Is it possible to use Windows Authentication to connect to a server?
Is there a way to use Windows authentication to create a connection?
This is what I'm trying to use:
conn = Create Database Connection ("DRIVER=SQL Server;SERVER=" || server || ";DATABASE=" || db || ";UID=" || uid || ";PWD=" || pwd || ";");
Re: Is it possible to use Windows Authentication to connect to a server?
It should be possible if the ODBC driver is set up correctly.  I would suggest connecting through the UI (Open Database or Query Builder) and then looking at the Source script that results from a query that you perform.  This script is in the jmp data table, in the leftmost upper pane.  You can right click to edit the script.  In that, you will see connection information that you can use for your JSL call.
Brian Corcoran
JMP Development
Brian Corcoran
JMP Development
Herrera5238
Setting up the ODBC was the first step that I needed, thank you!
From there this is what the script looked like for me:
Open Database(
	"DSN=[The name you gave ODBC];Description=[Description if you set one];Trusted_Connection=Yes;APP=JMP;WSID=[PC NAME];DATABASE=[DB Name];",
	"[Query]"
Overall though I would follow Brian's recommendation about using the UI and than you can just copy from there and apply it as needed.
Thanks for the response Brian!
