Is it possible to add labels to a line graph?
Is it possible to add labels to the points on a line graph? The numerical value. JMP Sample Data.PNG
Thierry_S
Re: Is it possible to add labels to a line graph?
There is no direct method to add labels to a Line + Scatter plot in GB. However, there is a trick that I use occasionally:
  1. Create your plot as usual
  2. Add a Bar graph layer (CTRL + Bar icon)
  3. Change the Bar style to Float
  4. Turn on the Label option
Best,
TS
Thierry R. Sornasse
Select the column with the values and select Cols > Label. Select all the rows and then select Rows > Label. Make your plot.
