  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
PeppeCanta
Is it possible in JMP to re-create the "INDEX(MATCH()) formula combination available in Excel?
This is the table I am working on:
In the column “Result” I want to put a particular value which respond to this rule:
  • If (“Y” is not 0) Return the “X” value contained in the cell with the same “NAME” as the current cell and with “ID” equal to the index indicated in “Y” (in this case 5).
  • Basically in the first row I want that “Result” contains “4.7”
@txnelson  you are the JMP wizard :) Do you believe it is possible?
Cheers
10 REPLIES 10
dexue
Re: Is it possible in JMP to re-create the "INDEX(MATCH()) formula combination available in Excel?
Great! Thanks Jim, modified a bit and works fine.
