FN
FN
Inserting additional values to existing keys in associative arrays (data dictionaries in JSL)
I cannot find the proper method to add new values to existing keys in associative arrays.
ex = Associative Array();
ex["a"] = {"10"};
ex["b"] = {"20"};
ex["c"] = {"30"};
// Add new value to "b" ex["b"] = {"21"}; show(ex); //ex = ["a" => {"10"}, "b" => {"21"}, "c" => {"30"}]; // Solution needed //ex = ["a" => {"10"}, "b" => {"20", "21"}, "c" => {"30"}];
Craige_Hales
Re: Inserting additional values to existing keys in associative arrays (data dictionaries in JSL)
Complete example, including the obvious way that does not work correctly.
// I wish the default value for AA's worked correctly with a list for the
// default, but it does not:
aa = [=> {}];
Insert Into( aa["fred"], 1 );
Insert Into( aa["ralph"], 2 );
Show( aa ); // aa = [=> {1, 2}]; ?!?!?!?!
// so you must do an explicit test and create the key/list like this:
aa = [=> ];
For( i = 1, i <= 3, i += 1,
	For Each( {key}, {"fred", "ralph"},
		If( !(aa << Contains( key )), // key does not exist?
			aa[key] = {};// add the key with an empty list
		Insert Into( aa[key], i );// insert into list
Show( aa ); // aa = ["fred" => {1, 2, 3}, "ralph" => {1, 2, 3}];
Craige
7 REPLIES 7
Treat the value ex["b"] like any other list.
ex["a"] = {"10"};
ex["b"] = {"20"};
ex["c"] = {"30"};
Insert Into( ex["b"], {"21"} );
Show( ex );
Craige_Hales
Mark's answer is the best. You can also do it like this
ex["c"][nitems(ex["c"])+1]="99";
which is uglier, slower, and less concise. But it might suggest other possibilities. Lists have a cool subscripting property for one-beyond-the-end that allows extending the list by one element.
Craige
FN
FN
I am actually using something more like this, so I guess I am missing an evaluation of the variable:
a_s = "a";
b_s = "b";
c_s = "c";
a_n = "10";
b_n = "20";
c_n = "30";
ex[a_s] = {a_n};
ex[b_s] = {b_n};
ex[c_s] = {c_n};
b_n = "21";
Insert Into( ex[b_s], {b_n} );
Show( ex );
// ex = ["a" => {a_n}, "b" => {b_n, b_n}, "c" => {c_n}];
vince_faller
The definition of list says that they aren't evaluated.
List: Creates a list of items without evaluating them.
Just wrap them in evallist()
a_s = "a";
b_s = "b";
c_s = "c";
a_n = "10";
b_n = "20";
c_n = "30";
ex[a_s] = Evallist({a_n});
ex[b_s] = Evallist({b_n});
ex[c_s] = Evallist({c_n});
b_n = "21";
Insert Into( ex[b_s], Evallist({b_n}) );
// or you could this it seems easier. // Insert Into( ex[b_s], b_n) ;
Show( ex );
Vince Faller - Predictum
FN
FN
This works, but if a given key is not existing, then I cannot insert new elements into it.
Regardless if the key is already there or not, is there a simple way to either introduce a new key-->value or insert a new value?
Craige_Hales
I think you'll need to use an if statement to check if the key exists and create it if it doesn't. I usually do this by creating it with an empty list, then fall into the code that adds the new element to the existing list.
Craige
Craige_Hales
aa = [=> {}];
aa = [=> ];
Craige
