robot
Insert a Expr() object into another script as an unevaluated Expr() object to be used later?
Adding to @jthi 's answer at Insert contents of Parse expression rather than variable name into New Script, how to insert a Expr() object into another script as an unevaluated Expr() object to be used later?
I am using JMP 18.1.2
dt = New Table( "My Table" );
e1 = Expr(
	Print( "Run some code." )
e2 = Expr(
	e1;
	Print( "Run some other code." );
e3 = Eval Expr(
	Expr( Name Expr( e1 ) ); // Define, but do not evaluate e1 here.
	Expr( Name Expr( e2 ) ); // Evaluate e1 here.
Show( e3 );
Eval( Eval Expr( dt << New Script( "Test", Expr( Name Expr( e3 ) ) ) ) );
Re: Insert a Expr() object into another script as an unevaluated Expr() object to be used later?
You can also wrap it into extra Expr
dt = New Table("My Table");
e0 = Expr(e1 = Expr(Print("Run some code.")));
e2 = Expr(
	e1;
	Print("Run some other code.");
e3 = Eval Expr(
	Expr(Name Expr(e0)); // Define, but do not evaluate e1 here.
	Expr(Name Expr(e2)); // Evaluate e1 here.
Show(e3);
Eval(Eval Expr(dt << New Script("Test", Expr(Name Expr(e3)))));
Level XII
A nice trick in JMP:
you can press the Enter Key on the numeric keyboard to run one line of code.
This is very helpful for debugging.
another trick:
right click into the script window and activate:
the last trick:
mark the Eval Expr(...) inside an Eval() and "run" it to check if the expression is what you expect:
This shows that where you write
Name Expr just takes the Expression which is stored in the variable. It doesn't evaluate it. e1 stays  e1.
Edit:
But maybe this is what you want to achieve? No question - just a comment?
The JSL script will write "e1" into the table script.
And JMP will try to evaluate e1 when the user runs the table script.
This means: you have to define e1 in the context of the data table, otherwise you will get an error message:
[e1 is just defined within the here namespace of the script]
I'm not exactly sure what you are going for as e1 has already been defined on line 5. What do you wish to have inside e3? Something like this
e1 = Expr(Print("Code"));
e1; //e2
Print("Code2"); //e2
Or
Print("Code");
robot
Thanks @hogi and @jthi for the input.  I was able to achieve the result I was looking for by using a function.
e1 = Expr(
	f1 = Function( {},
		{Default Local},
e2 = Expr(
	f1();
e3 = Expr(
	f1();
	Print( "Run even more code." );
e4 = Eval Expr(
	Expr( Name Expr( e3 ) ); // Evaluate e1 here.
Eval( Eval Expr( dt << New Script( "Test", Expr( Name Expr( e4 ) ) ) ) );
e2 = Expr(
	e1;
e3 = Eval Expr(
Show(e3);
robot
Very clever!  Thanks.
