juliet
Insert Legend command into pre-scripted Variability chart
Hi All,
I feel a little silly that I can't figure this out, but I can't seem to add a legend to my variability chart script. I'm trying to add a legend for my "Ova" column. The row states have already been set, so I don't need that command. So from what I've read, I should be able to use something like this:
Report ( var ) [FrameBox(1)] << Row Legend ("Ova")
But that isn't working.
Here is the whole code for my variability chart. My only thought is that I'm not putting the legend command in the right place?
st = Data Table( "JoinedSubset");
st << Variability Chart(
  Y( :LLOD CFU ),
  X( :Media, :Temp, :Timepoint ),
  Max Iter( 100 ),
  Conv Limit( 0.00000001 ),
  Number Integration Abscissas( 128 ),
  Number Function Evals( 65536 ),
  Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
  Process Variation( 0 ),
  Variability Summary Report( 1 ),
  Std Dev Chart( 1 ),
  Points Jittered( 1 ),
  Dispatch(
  {"Variability Chart for LLOD CFU"},
  "2",
  ScaleBox,
  {Min( -100 ), Max( 500 ), Inc( 100 ), Minor Ticks( 1 ),
  Rotated Labels( "Horizontal" )}
  Dispatch(
  "Variability Chart",
  FrameBox,
  {Frame Size( 590, 217 ), Marker Size( 4 )}
Thanks very much for any and all help!
dfmoore
Re: Insert Legend command into pre-scripted Variability chart
Here's in example using some of the JMP sample data. Hope it's helpful!
Daniel
Variability Chart(
    Y( :weight ),
    X( :sex ),
    Max Iter( 100 ),
    Std Dev Chart( 0 ),
        Dispatch(
            {"Variability Chart for weight"},
            FrameBox,
            {Row Legend(
                age,
                Color( 1 ),
                Color Theme( "JMP Default" ),
                Marker( 0 ),
                Marker Theme( "" ),
                Continuous Scale( 0 ),
                Reverse Scale( 0 ),
                Excluded Rows( 0 )
dfmoore
Daniel
Variability Chart(
    Y( :weight ),
    X( :sex ),
    Max Iter( 100 ),
    Std Dev Chart( 0 ),
        Dispatch(
            FrameBox,
            {Row Legend(
                age,
                Color( 1 ),
                Marker( 0 ),
                Marker Theme( "" ),
                Reverse Scale( 0 ),
                Excluded Rows( 0 )
juliet
That worked! Thanks so much!
