hogi
Level XIII
Inherited Plot settings
I noticed some strange behavior in Graph Builder which is caused by the fact that formatting like
One example:
If the top-most plot (#1) has some specific settings and this plot is removed, instead of removing the settings with the subplot, the settings are then applied to the plot which is now @ "top" (old #2 -> new #1).
So, old plot #2 will inherit the color settings and the manually changed axis label of plot #1:
Graph builder: bug when dragging subplots
Seems that other users have similar issues, like here with axis labels:
Manual axe labels are mixed up when plotting multiple columns
what is the best workaround at the moment?
What I do: save the script to a script window, change the settings there and run the script. For complicated plots this is a lot faster than applying all settings again. And it's happens so easily that you miss one of the erroneously "shifted" axis labels - much more visible in "script" mode :)
(view in My Videos)
0 REPLIES 0
