SaraA
Information tools for analysis of Definitive Screening Designs
In the JMP course on Statistical Thinking for Industrial Problem Solving, the module on DOE does not handle the specific analysis of Definitive Screening Designs (DSD). Any other source of information that can be helpful for someone who is more familiar to the analysis of factorial designs but new to DSD analysis?
Thank you
Sara
Victor_G
Re: Information tools for analysis of Definitive Screening Designs
Hi @SaraA,
When using the "Fit Definitive Screening", the analysis of Definitive Screening Designs is done in 2 steps to take into account the specific structure of DSD:
  1. First stage involves main effects identification with the responses values,
  2. Second stage involves 2-factors interactions and quadratic effects identification (based on Effects Heredity principle) with the responses residuals from the first stage model.
To learn more about the analysis method of DSDs available in the "Fit Definitive Screening Design", I can recommend some ressources and presentations :
I hope these ressources will help you understand the logic behind this analysis method and model fitting.
Victor GUILLER
Victor_G
Hi @SaraA,
Victor GUILLER
