Improve linear model
Attached is a Residual by Predicted Plot for some model built on historical data from some process.
When you see such a graph for residuals, what would you recommend to change in the model in order to solve the slope and make residuals be randomly distributed around 0?
Thanks in advance!
Re: Improve linear model
I retract the idea of no intercept. I also think it is a strong linear effect missing from the model.
Just reviewed my Fit Model dialogue window and found out "No Intercept" was checked!
Unchecking it resolved the problem, attached is the resolved Residuals Plot.
Can I ask you how did you know that from this plot? Besides tons of experience, that i guess you have...
And, if you see abnormalities in the attached improved plot, I'd also be glad to know.
Thanks a lot!
7 REPLIES 7
P_Bartell
Level VIII
Can you share the data and model specified that resulted in the residual plot you shared? And some context on the practical problem/issue you are trying to resolve? Lacking these three things it's hard to recommend a next step that would achieve your goal.
Thank you for you reply
Unfortunately, the data are sensitive and cannot be shared :(
i will try to optimize with all the feedbacks i've got
P_Bartell
Level VIII
Understood about the '...sensitive...' nature of your data. Not uncommon. But did you know within the JMP ecosystem there is a pathway to anonymize data that is easy to use and works for many users? It's described here in the JMP documentation: Anonymize Data in JMP
MRB3855
Hi @LambdaCapybara4 : As @P_Bartell  indicated, it is hard to diagnose with the limited information given. That said,  my guess would be that your model is missing a predictor.
Thanks a lot!
MRB3855
