samir
Import (open) data from websites
I am trying to import data from a web page, but it fails although I use the exact syntax mentioned in the documentation.
Here is the code I use:
My_URL=https://www.jetairfly.com/fr/last-minute/charleroi/bejaia;
ObjectName = Open(My_URL, HTML Table(1));
Here is the error message I get:
Unable to read data from "https://www.jetairfly.com/fr/last-minute/charleroi/bejaia" in access or evaluation of 'Open' , Open( My_URL, HTML Table( 1 ) )
In the following script, error marked by /*###*/
ObjectName = Open/*###*/(My_URL, HTML Table( 1 ))
Could someone help ?
Thanks.
Re: Import (open) data from websites
Internet Open support for HTTPS sites was added in JMP 12, so you won't be able to open this URL in JMP 11.
ian_jmp
Level X
I had JMP generate the scripts below for by (by using 'File > Internet Open' and copying the 'Source' script it puts in the table):
Open(
"https://www.jetairfly.com/fr/last-minute/charleroi/bejaia",
HTML Table( 1, Column Names( 1 ), Data Starts( 2 ) )
Open(
HTML Table( 2, Column Names( 1 ), Data Starts( 2 ) )
Please try these.
samir
No it does not work, does if for you ?
I get the same error.
Strange enough, when I used 'File > Internet Open', I got a different source code...
I am using JMP11, could this be the reason ?
ian_jmp
Level X
I'm using JMP 12 (on a Mac) and, yes, it worked for me.
