Resheffink1
If statement not working in jsl
Hi all.
Can you please check what is the problem with my if statement? I want to run several jsl commands in case the condition is true (in my case, that the spec file name is as written in the code) but it does not work.
Everything else is working fine, just the if statement is not.
My JMP version is 18
dt = Current Data Table();
dt << Select Columns( :PARAMETER );
dt << Text To Columns( delimiter( "_" ) );
dt << delete columns( :PARAMETER 1 );
If( :SPECFILE == "MS-SMLD",
	:PARAMETER 2 << set name( "Column_name1" );
	:PARAMETER 3 << set name( "Column_name2" );
	:PARAMETER 4 << set name( "Column_name3" );
	:PARAMETER 5 << set name( "Column_name4" );
	:PARAMETER 6 << set name( "Column_name5" ) ;
	If( :SPECFILE == "SMLA", Formula(
		dt << delete columns( :PARAMETER 5 );
Thanks,
Reshef
Re: If statement not working in jsl
Might be enough if you changed :SPECFILE to SPECFILE (:SPECFILE would (usually) refer to a column).
Resheffink1
Hi.
Thanks! but the "SPECFILE" is indeed a column in my jmp table.
Anyway, I tried it and it does not work.
Maybe its what separate the jsl commands in my IF statement?
Or, maybe its impossible to run several jsl commands in one IF statement?
Thanks,
Reshef
Then you have to define the Row (Row() = 1; for example) or loop over the rows in your table using For Each Row. The "default" row in JMP is 0 which isn't valid row
If what you are trying to do, is to look at row 1's value in column "SPECFILE" and then make decisions based on it, the JSL below will be what you want
If(
	:SPECFILE[1] == "MS-SMLD",
		:PARAMETER 6 << set name( "Column_name5" );,
	:SPECFILE[1] == "SMLA",
