ChrisNally
If Statement to add a yes/no column
Good Morning
                         Any help here would be much appreciated. I am trying to add a new column that will add either a yes or a no based on a Bx no. range
So in table below any Bx No before 10732 would return a "Yes" in the 0.3mic column and any Bx No after would return a "No".
Thanks in advance.
Chris
C_LOT_NAMEPRODUCTSAMPLE_TYPEAverage Pigment Strength0.3mic filtered
10128CYAN_J2VLOT_FINISHED
10128CYAN_J2VLOT_FINISHED10.14
10200CYAN_J2VLOT_FINISHED12.26
10240CYAN_J2VLOT_FINISHED12.06
10377CYAN_J2VLOT_FINISHED11.965
10487CYAN_J2VLOT_FINISHED12.145
10487CYAN_J2VLOT_FINISHED12.075
10634CYAN_J2VLOT_FINISHED
10634CYAN_J2VLOT_FINISHED12.195
10682CYAN_J2VLOT_FINISHED12.035
10697CYAN_J2VLOT_FINISHED12.1
10732CYAN_J2VLOT_FINISHED12.13
10733CYAN_J2VLOT_FINISHED12.265
10871CYAN_J2VLOT_FINISHED12.155
10872CYAN_J2VLOT_FINISHED12.155
10873CYAN_J2VLOT_FINISHED12.035
10874CYAN_J2VLOT_FINISHED12.145
Re: If Statement to add a yes/no column
Try this
dt << New Column( "0.3mic filtered ",
	Character,
	Nominal,
	Formula(
		If( Num( :C_LOT_NAME ) < 10732,
			"YES",
			"No"
ChrisNally
 I tried this but only get No returned in the column:
    Character,
    Nominal,
    Formula(
        If(
            :C_LOT_NAME == "<10732"
            "YES",
            "No"
Try this
	Character,
	Nominal,
	Formula(
			"YES",
			"No"
ChrisNally
Hi
     Thank you very much, this worked well. Your help is much appreciated.
Regards
Chris
