karmstro
IS NUMBER IS MISSING etc.
I have the following snippet of JSL that checks the My_Graphs list to determine whether the ith row is a number or not and do one of two things (col 6 consists of numbers and "."). The first part of the IF works - it sets the chart min at 1.2 the LCL and draws the plot. However, if the LCL is "." it does not set the LCL to 0. Immediately below is the the first 6 rows of col 6.
0.25
-2
-0.018
0.25
if(Is Number(num(My_Graphs [6][i])),
(Plot << dispatch(
{"Variability Chart for..."},
"2",
ScaleBox,
{Min(num(My_Graphs [6][i]) * 1.2 ),
Add Ref Line( num(My_Graphs [6][i]), Dotted, "Red", "LCL = " || My_Graphs [6][i] , 2 ),
Show Major Grid( 1 )})
(Plot << dispatch(
"2", ScaleBox, {Min(0)})
);//end if
kevin_lennon
Re: IS NUMBER IS MISSING etc.
Kev - let's have a chat about this in work...But I think I see your problem.
JMP treats a missing number as a number. So when you execute the code below it returns "It's a number" for every element of num_list.
num_list = {.,0.25,-2,-0.018,.,0.25};
for(i=1,i<=nitems(num_list),i++,if(IsNumber(num_list[i]),Print("It's a number"), Print ("It's not a number")));
What I suggest you do instead is change your if condition to handle the missing one first, followed by is number and then some catch expression.
for(i=1,i<=nitems(num_list),i++,if(IsMissing(num_list[i]),Print("It's Missing"), IsNumber(num_list[i]), Print ("It's a number"),Print("I don't know what to do now")));
10 REPLIES 10
Craige_Hales
x=.;
show( x, isNumber(1), isNumber(0), isNumber(.), isMissing(0), isMissing(.), if( x==x, "yes", "no") )
x = .;
Is Number(1) = 1;
Is Number(0) = 1;
Is Number(.) = 1;
Is Missing(0) = 0;
Is Missing(.) = 1;
If(x == x, "yes", "no") = .;
Missing values are numbers and require the isMissing function to test for them.  A comparison against a missing value returns missing, not 0 or 1, even if both values are missing.
Craige
karmstro
This should work then but it doesn't?
if(!Is Missing(My_Graphs [6][i]),
(Plot << dispatch(
{"Variability Chart..."},
"2",
ScaleBox,
(Plot << dispatch(
);//end if
Jeff_Perkinson
When you say it doesn't work, what exactly do you mean? Are you getting an error? Is the graph updated incorrectly? Not at all?
Can you add a
Show (My_Graphs [6][i]);
just before your conditional to see what the value is?
-Jeff
karmstro
It seems that it doesn't evaluate the false condition for !Is Missing but there's no error.
It updates the min and adds the chart line when there is a value but doesn't set min to 0 for false condition of if.
Jeff_Perkinson
We know that the Is Missing() function works. For example:
For( i = 1, i <= N Items( x ), i++,
	Print( "starting iteration " || Char( i ) );
	If( !Is Missing( x[i] ),
		Show( x[i] ),
		Print( "x is missing" );
		Show( x[i] );
/*: "starting iteration 1" x[i] = 1; "starting iteration 2" "x is missing" x[i] = .;
So it must be something with the data/values that you're passing to it. That's why the Show() that I suggested above will help.
Maybe you should put a debugging "Show()" in the else clause of the If() as well to show whether it got in there or not.
-Jeff
karmstro
I'm passing it values from a list created with Summarize which are quoted values?
karmstro
When I run the following code I get:
For( i = 1, i <= number, i++,
show(My_Graphs[6][i]);
My_Graphs[6][i] = ".";
My_Graphs[6][i] = "0.25";
My_Graphs[6][i] = "-2";
My_Graphs[6][i] = "-0.018";
When I run the followng code I get:
show(Is Missing(My_Graphs[6][i]));
Is Missing(My_Graphs[6][i]) = 0;
show(Is Missing(num(My_Graphs[6][i])));
Is Missing(Num(My_Graphs[6][i])) = 1;
Is Missing(Num(My_Graphs[6][i])) = 0;
It looks like  have to covert the list strings to num for the Is Missing function.
Jeff_Perkinson
The quote marks indicate that your values are character strings. As such you'll need to convert them to numbers using the Num() function in order to use the Is Missing() function.
So it should be:
if(Is Missing(num(My_Graphs [6][i])),
(Plot << dispatch(
"2",
ScaleBox,
(Plot << dispatch(
);//end if
Which is really close to what you had originally.
Alternatively, you could compare against the text string "." like this:
if(My_Graphs [6][i] == ".",
(Plot << dispatch(
"2",
ScaleBox,
(Plot << dispatch(
);//end if
-Jeff
kevin_lennon
