samir
How to use scrollBox
I put a few strings in a scroll box in view of selecting one and using it later in the script...But I see no way to get the string that is selected by the user.
Example: in the following script we get a list of strings "first Item", "Second Item", ...
Once the user selects the "Second Item", how can I extract this information ?
Thanks a lot.
win = New Window( "Example",
	sb = Scroll Box(
		Size( 250, 75 ),
		List Box(
			{"First Item", "Second Item", "Third Item", "Fourth Item",
			"Fifth Item"},
			width( 200 ),
			max selected( 2 ),
			nlines( 6 )
win << Set Window Size( 300, 200 );
Re: How to use scrollBox
You need to add a pointer to the actual list box().  Then you can access the various items/features you want.  See my script below.  All of this is available in the scripting index
     Help==>Scripting Index
	sb = Scroll Box(
		Size( 250, 75 ),
		lb = List Box(
			"Fifth Item"},
			width( 200 ),
			max selected( 2 ),
			nlines( 6 ),
			show(lb<<get selected);
samir
You are right,
I did not think of pointing to the list itself...And the "get selected" does the job.
Many thanks.
